Stumped by LZW45 LED strip buttons
I’m a pretty low-skilled user of my Hubitat but recently added a LZW45 light strip under my kitchen counters. I installed the drivers and connected the device to my hub with little issue (though I had to delete a section of the driver that kept giving me an error).
Something I can’t get to work is controlling the dang thing with the buttons on the controller directly. If I hold the up button the dimmer goes to full, and down to off, and I changed the ramp time. But how can I just hit the big button to turn it on and off? Is there a way to cycle through colors using just the controller?
I tried using the Advanced Button Controller app on Hubitat to set these up through there, but I can’t get it to do anything. I feel like I’m missing something big and obvious here.
Which part did you have to remove from the driver? I’ve never had an issue with it.
For button controls look at the manual. https://support.inovelli.com/portal/api/kbArticles/407409000017735021/locale/en/attachments/ko2kb7a3e9a2147334df6ac45cda03aa0b360/content?portalId=edbsn8bb12d5f5a97d693e61ce4ce8a23f8b0e323eac44a6c2794f893e912acf005df&inline=true
When I had the strip I would just control it from the device parameters via browser vice setting up scenes from the controller.
i too would like to know if this is possible, currently ran into another issue with a black series dimmer and some hue bulbs but ill look into this when i have the chance.
