Switch/hub/app setup to allow max dimming setting
What switch/hub/app do I need to be able to set the max dim level on a light?
By set a max dim level on a light, do you mean via a switch or the lightbulb itself?
Any of SmartThings/Hubitat/HomeAssistant are able to work with the parameters on Inovelli’s smart switches to adjust max dim level if that’s what you’re looking for?
This should be able to be set local to the switch also, but I can’t find exactly which setting it is.
