Triggering LED default on level Home Assistant
I’m using Home Assistant and I’ve got a script that changes the color and brightness of the LED strip on a VZM31-SN using “Issue effect for all LEDs”. I’m manually setting the brightness for both On and Off. The switch is in a block with 2 other VZM31-SN. I’m having trouble setting the ON and Off brightness to match the other two. Is there a way to just not set the brightness and just force it to accept the default on and off values?
I guess in my head, I’m thinking there should be a “set all LEDs to default values”?
Zwave has 4 parameters for the LED bar color and level for on and off. I would have expected the same 4 for the Zigbee version. Are you sure it’s not just the script forcing you to do set all 4?
The parameters might be disabled, a lot of them are for these devices.
Yep, Zigbee has four as well, P95 - P98. Two for color on and off, 2 for intensity on and off.
Thank you for the response. I’m pretty sure I’m understanding what you are saying…I presume these are the parameters you are talking about?
Screenshot 2025-04-16 at 2.47.35 PM
Assuming so, I guess I’m not asking my question correctly. How do I call a method to reset the color and intensity back to default? I see how I can set the default values, but I can’t figure out how to set the LEDs back to the default values? The best I can figure out is that I have to call the issue_effect_for all_led and manually set numbers to match my default values. This doesn’t make sense to me as it makes no point to have default values if I can’t call a method to set them?
type: issue_all_led_effect
domain: zha
device_id: 1565a9dbc85eb020065c98262a75961a
effect_type: Solid
color: 90
level: 25
duration: 255
