Unable to reset Inovelli RGBW Bulb
Hi guys!
I have 2 RGBW Inovelli Bulbs that I am unable to reset using the on/off six times where I am ensuring to take 1 second between on and off. My bulbs are stuck at a blue color. Not sure if it matters but I use a Smartthings V2 Hub; the bulbs are not on the Smarthings app as I have previously removed. Can anyone help?
Even though you have removed it, you should be able to do a general exclusion, which should also reset the bulb:
Exclusion (Factory Reset)
Before putting your hub/gateway in exclusion mode, remove power from the bulb (unscrew it, flip switch down, etc).
  1. With power removed from your bulb, put your hub/gateway in exclusion mode
  2. Restore power to the bulb and it should flash 2x indicating it’s in exclusion mode
  3. If successful, the bulb should flash a third time
In ST, you’ll find the general exclusion under the hub’s Zwave utilities.
Of course. I am such a dummy when it comes to placing hubs in Exclusion Mode to ensure full deletion! This worked. I’ve got a happy wife now since she intends on using the bulbs in the nursey.
We should all be so lucky!
