I’m using an Inovelli Blue VZM31-SN and Home Assistant with Zigbee2MQTT.
Is there a way to use the single-click of the config button to set it to a specific brightness without the use of Home Assistant? I can, and know how to create single/double/triple click automations within home assistant to set the brightness of the light. But, I’d like my Innovelli switches to have base functionality similar to a dumb switch for my guests. And that is single-click up/down = on/off, double-click up/down = full brightness/dimmest setting, hold-up/down = brighten/dim. The only button that eludes me is the button to “set the brightness to X value”.
Can this be done without the use of home assistant?
If the answer is that it can’t be done without a hub, I’ll take it. I rather know that a hub is required than spend a half an hour every night googling for answers.
