VZM35-SN Local control not communicated to hubitat
I just installed 7 VZM35-SN and 25 VZM31-SN. My dimmers all work perfectly. I can control from hubitat or the switch itself and the status is instantly reflected in hubitat. However all of my fan units (VZM35-SN) work from hubitat and locally but only commands sent by hubitat are reflected in their status. If I turn a fan on from the switch hubitat will still show its off. None of the scene buttons work either. Nothing in the logs on hubitat for any local commands.
The fans are running FW 1.07 with the 2024-05-30 driver loaded
Hubitat is a C8 Pro running 2.3.9.193
Figured out the configure all option fixes the issue.
