VZW31 Dimming Hue Bulbs
I have a VZW31 dimmer wired in a single pole config in smart bulb mode. I am on Home Assistant ZwaveJS. I am trying to dim two Hue bulbs that are not plugged into an outlet controlled by the switch. I was able to load the posted Blueprint, but I do not see an option to dim, only on/off or toggle. I have a ZoozZEN34 remote switch that has a similar blueprint with dimming as an option. Here: blueprint tutorial for Zen34 · GitHub
I think the Zooz blueprint just uses steps of dimming. I don’t see that option with the VZW31.
