I am trying to use the LED on my VZW32-SN in rules any guidance in how to do that? Thanks!!!
Guessing you’re referring to the Zwave mmWave dimmer? I corrected your model number.
Yes I did, thanks for correcting the model number! Hopefully I can get some guidance on that. Thanks!!!
What specifically are you trying to do? Change the color of the LED, perhaps? Or set notifications?
Your profile says you are using a Hubitat hub. See if these help:
Thanks for the info. I have all that working without a problem, have many now all included in my hub, all with muti-tap functions, and all with the basic changes on the LED color for on/off as it is directly available on the driver from Inovelli. All good there. What I want to do know is to do something like if the garage door is left opened more than 5 minutes start blinking the LED in red. That I have not found a way to do.
There are a couple ways in Hubitat to set automations, Basic Rules and the Rule Machine. Basic Rules should be in Apps by default. Rule Machine is built-in but must be enabled.
You can set an automation to flash the LEDs on the switch after a sensor is open for a period of time with either. You’ll be turning on a notification by specifying FOUR parameters. There is a Google query at the bottom of this post that will get you started. The AI overview should suffice.
I THINK you may need to set two rules, one to turn it on and the other to turn it off when the door closes. When you set a notification on the switch, the four parameters you need to specify are Effect, Color, Level i.e intensity and Duration. They may be named slightly differently in the Hubitat driver.
I’m going to defer to others here that are experienced in Hubitat rules if you need further help.
Thanks very familiar with Rule Machine, I just cannot find a way to find what those parameters are and how to access them from Rule Machine.
I apologize I can’t be of much help here - I do not have any Reds with my Hubitat, so I’m not sure if Red’s LED-bar control options work similarly to Blues or not.
Thanks, would you mind to share how you are doing it with the Blues to see if I can find any similarity?
I basically use the concepts from this help article:
Thanks so much! Super helpful! I wanted to use the LED Mini-Dashboard as well but unfortunately the VZW32-SN is not showing up there yet… anybody on the community knows if that can be updated to include the driver for VZW32-SN, it is the RED series mmwave dimmer. Thanks all!!!
I ended up finding this, installed it and it is working like a charm, super helpful: LED Mini-Dashboard (replacement for "Switch Dashboard" and Switch Notifications) for Inovelli dimmer/switches - #307 by augustov - ⚙️ Custom Apps and Drivers - Hubitat Hopefully it helps others with the same question!
Of course it would be great if @inovelli1 would take ownership of this app and maintain it in Hubitat Package Manager. Thanks all!!!
