White On/Off - Outlet question
Actually I figured this use case by myself.
However, I want to ask if there is any recommendation on how to support the switch for outlet? Is it supported?
I’m not quite sure what you are asking.
The White On/Off is rated for use with an outlet so long as the load on that outlet does not exceed the switch’s max load requirements.
