Wiring Help with a Casa Vieja fan
Hi all - I bought the LZW36 after the existing remote in my fan died inexplicably. The remote controls both the light and the fan and had 5 speed options + reverse.
When I took it down, however, I found myself confused as to how to connect the inovelli module to the fan itself.
The old remote module had 5 wires going into the body of the fan: a Black, While and Gray, all labeled “for motor” and Blue (Load) and Orange (Neutral) labeled for the Light Kit.
The Load and Neutral for the light kit are pretty self-explanatory, but I’m having trouble making sense of the three wires for the motor.
I tried connecting the white and orange wires from the fan to the white wire from the control unit, to the neutral from the ceiling to no avail. I also tried including the gray wire in that bunch as well - still nothing.
The thing that made me most nervous was that the motor ‘growled’ but never actually spun once I turned the power back on.
Any suggestions?
5 speed options and a reverse? That sounds more like a DC setup and the LZW36 is only compatible with AC motors. Do you have the fan model to confirm?
It’s a Windspun Modern Hugger - the part number is 1W415-1W424-1W425. I had wondered if it wasn’t a DC motor, but didn’t see any indication either way.
Thanks for your help! Will.
52" Windspun Walnut - Nickel LED DC Hugger Ceiling Fan
With walnut finish solid carved wood blades, this LED hugger ceiling fan has a handsome look. Find modern style and a nice, refreshing breeze with the Windspun LED DC hugger ceiling fan. The stylish design features a brushed nickel finish on the DC motor, and is paired with three walnut finish solid wood carved blades and an energy-efficient LED light kit to complete the design. Includes a full function 5-speed hand held remote control with on/off light operation for easy operation.
There we go. Thanks all.
