Then again it could be a neutral somewhere. Cause the dumb switch does not have a neutral hooked up.
For what ever reason I now have 2 brand new smart switches that don’t work anymore.
Awfully expensive day.
Put a new smart switch in and now it’s working.
Did you configure the smart switch parameters to tell it to be a 3 way toggle?
I think it’s a switch, not a dimmer.
Yup just a switch, put another new smart switch in and all is well.
Must not be running latest firmware then.
Glad you got it figured out @gurule31.
Just FYI for future people that may have problems in a 4 way setup using the black series on/off switches.
My issues were in no way related to firmware.
My particular 4 way setup has never worked right since we bought the house, but I finally decided I was gonna fix the issue.
I did finally end up getting it wired and working correctly.
In the process I fried one switch cause a ground wire touched the load screw. Another switch still works but the load screw will not tighten anymore. So I guess I need to reach out to support for a replacement.
Moral of the story is oldish wiring is lame, and be careful you don’t ruin a 40 dollar switch.
I wasn’t sure if I should post this here or not.
Can I still use smart bulbs in this scenario, with having 2 dumb switches and 1 smart switch?
