I just installed my first 2-1 switch. I ended up wanting to replace two switches that controlled 3 lights in one room.
Originally, the line in was pigtailed to the two switches (and for something else, presumably the outlets for the room). The load wires going out from each switch were the red & black from a 4 wire bundle (sorry, I lack the proper terminology).
So I removed one of the pigtail line wires and wired the following to the 2-1 switch:
- The one line wire
- The neutral wire
- The red & black load wires in the two available wire holes
Logic tells me that it’s fine to wire it this way as I don’t think I’ve changed anything about what electricity is being sent through the wires, but I wanted to ask to see if someone more knowledgeable could share if this was an okay thing to do (the two load wires in the switch).
