ZHA and Z2M Visualizer HA addon for VZM32-SN MMWave Blue
Hey,
I have been a bit busy and added ZHA support for visually configuring zones for your mm wave blue switch in Home Assistant. ZHA support is experimental for the moment but for my basic testing it was working.
Z2M was already working well in the addon.
Anyway, if you want to test it out its on my github. Review the readme’s for instructions on setup.
-Nick D
Thank you for creating this. I’ve been using it for a while with Z2M and find it indispensable for configuring these switches. Getting eyes on what’s happening with the sensor took a lot of frustration out of the experience.
@nickduvall921 Any chance it can be made compatible with the zwave version?
Unfortunately there doesn’t appear to be a way to pull the live tracking data from the zwave switches. They mentioned that due to the zwave chip having less flash space they had to remove some stuff from the firmware, like reading the target data.
edit: looking at the Red changelog, it looks like you can pull the data now, unfortunately i don’t own a red switch so i would have no way to test if anything works.
@nickduvall921 Any way I can help with the testing?
sorry for the late reply. sure, i posted some instructions on the github issue. i added a packet capture in the current version of the addon Inovelli mmWave Visualizer for ZWA Plans? (Feature Request) · Issue #42 · nickduvall921/mmwave_vis · GitHub
If you can capture some packets and post them then i can determine if its doable and if it is I can probably roll it out in the next release.
Edit: looks like its still not possible.
