Zigbee / Matter Motion Switch | Project Linus (Blue Series)
Project update: I sent an email our recently that outlined the latest, so if you didn’t get it, here’s what was posted in it:
Hey all,
Quick update about the Blue Series mmWave switch – we will be receiving our beta samples (finally) next week (pictures below) and can finally start beta testing. The good news is that Eric M (CTO) and I have been testing these out for a while now and wanted to get it in a good spot for beta testing. There’s been a lot of difficulties with the mmWave sensor that we had to work through, but we feel ready to let the bigger team start testing.
In addition, the switches have started ETL Certification, FCC Certification, IC Certification and are progressing nicely.
Part of this process also includes setting up a trial-production run, which has been completed.
Image item600xauto
In terms of the overall timeline, I’ve come to just accept that there will be delays and while any delay we take is disappointing, at the end of the day, I want you guys to have an amazing switch that you’re excited to have in your home. Our standards are, and have always been, extremely high (we put these in our own homes too), so sometimes that can cause initial timelines to become more fluid.
It’s possible we may still hit the July production schedule, but that will all depend on how beta testing goes.
The important thing is that we continue to see progress, which we have. This manufacturer has done things a little differently, in that they like to get as much completed as possible before sending off beta units whereas our other manufacturer takes the approach of building our switches together, which means the first couple iterations may not be on par with our expectations. In other words, the mmWave manufacturer takes the approach of getting their ducks in a row before sending off for us to test and the other one is more of a, “build it as you fly it” type manufacturer. We prefer the latter, but I’m not sure which approach is right/wrong.
Anyway, as always, we appreciate your patience as I know we’re way behind schedule and I know you all are excited about this project.
The update is that we received the beta samples and are waiting for an OTA from the manufacturer on some bugs they found with the mmWave sensor itself.
Here are some pics:
25 Z-Wave and 25 Zigbee
Overall, the tooling looks/feels great. If you didn’t know, you wouldn’t be able to tell these came from a different manufacturer than our current 2-1/Dimmer switch.
I did have some feedback for them, which is outlined below. It should be an easy fix.
Overall, the switches look really good and feel really good. Nice job! There are a few minor things to change and make sure it’s ready for production:
Air-Gap needs to be level with the outer frame:
If you’re looking at the switch, the top left side screw needs to be red
If you’re looking at the switch, both screws on the right side need to be black
The ground screw plate still wiggles – it shouldn’t wiggle at all
The ground screw should be green
The ground screw plate should not be visible when the ground screw is fully loosened. It should look like our current switches
For the Zigbee version, the back part should be blue as shown below:
For the Z-Wave version, the back part should be red as shown below
Two sections below should be flush similar to the current samples
The stopper on the screw is too loose and falls off easily so we’ll need a tighter one.
So, the next step is beta testing, which will really determine when these will be released. As stated in the email, I know we’re really far behind schedule and it sucks. But at the end of the day, this is the first switch of its kind and I want it to be something we’re all proud of. I’m excited to see progress and it is a major milestone in the project to have beta samples where tooling is basically completed.
Let’s all rally around there being a great beta test!
Edited to add: if you haven’t been receiving status update emails, please make sure to sign up for them here: mmWave Presence Sensor Smart Switch (Radar Equipped Millimeter Wave) – Inovelli
Scroll down to after where it says, “Pre-order” and look for this section:
