Recently got a bunch of the new Inovelli Aux switch and was wondering if I can use them with the Zooz ZEN71 On/Off switch for a 3 way set up given that the Inovelli Z-Wave switches are still many months away from becoming available.
Thanks
Thanks
You may need to reach out to Zooz to see if the ZEN71 supports momentary switches as a companion switch. Looking at the manual I only see dumb switches as part of the wiring, but Zooz support will know.
ok thank you emailed Zooz and they replied very quickly with a negative. Appearantly the Zooz switches are uniquely designed to work with mechanical dumb switches. The trade off is that it doesn’t work with any type of aux or momentary switch
