Zwavejs how to get config parameter in node red
In node red at runtime how can I retrieve parameters from zwavejs2mqtt? I know I can set them with bulk_set_partial_config_parameters. I tried posting on node red forum but haven’t gotten a response.
I dont think there is a way to get config values currently through Home Assistant. However, you can do it with mqtt:
topic: (may vary based on your setup)
zwavejs/_CLIENTS/ZWAVE_GATEWAY-zwavejs2mqtt/api/pollValue/set
payload:
    "args": [
            "nodeId": 49,
            "commandClass": 112,
            "endpoint": 0,
            "property": 13
or
    "args": [
            "nodeId": 49,
            "commandClass": "Configuration",
            "endpoint": 0,
            "property": 13
I haven’t gone down the mqtt rabbit hole yet. I’ll look into it.
