2nd Gen Switch with HomeAssistant - Shows as, "Inovelli Unknown" and not, "Switch"
i am having the exact same issue. i replied to another thread with users having this issues here: LZW31-SN Dimmer, Manual turn on no state reporting - #5 by smos08
this is my first zwave device as well as inovelli switch. using zwave2mqtt every other sensor works fine and i can even see the power change but it does not update the status in HA. i can control from HA without issue. here are my debug logs when adding a device and manually toggling from the switch, you can see the power usage change but nothing coming from the state change
2020-04-12T20:00:46.678Z z2m:Zwave Success zwave api call addNode true
2020-04-12T20:00:46.680Z z2m:Zwave controller command { nodeid: 0, state: 1, errcode: 0, help: ‘AddDevice Starting’ }
2020-04-12T20:00:46.681Z z2m:Zwave controller command { nodeid: 0, state: 4, errcode: 0, help: ‘AddDevice Waiting’ }
2020-04-12T20:00:59.620Z z2m:Zwave controller command { nodeid: 0, state: 6, errcode: 0, help: ‘AddDevice InProgress’ }
2020-04-12T20:00:59.809Z z2m:Zwave controller command { nodeid: 4, state: 6, errcode: 0, help: ‘AddDevice InProgress’ }
2020-04-12T20:01:00.123Z z2m:Zwave controller command { nodeid: 4, state: 6, errcode: 0, help: ‘AddDevice InProgress’ }
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 0 (COMMAND_CLASS_NO_OPERATION)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 114 (COMMAND_CLASS_MANUFACTURER_SPECIFIC)
2020-04-12T20:01:00.180Z z2m:Zwave Node added 4
2020-04-12T20:01:00.180Z z2m:Zwave ValueAdded: 4-94-1-0 ZWave+ Version
2020-04-12T20:01:00.181Z z2m:Zwave ValueAdded: 4-94-1-1 InstallerIcon
2020-04-12T20:01:00.182Z z2m:Zwave ValueAdded: 4-94-1-2 UserIcon
2020-04-12T20:01:00.182Z z2m:Zwave ValueAdded: 4-38-1-0 Level
2020-04-12T20:01:00.183Z z2m:Zwave ValueAdded: 4-38-1-1 Bright
2020-04-12T20:01:00.183Z z2m:Zwave ValueAdded: 4-38-1-2 Dim
2020-04-12T20:01:00.184Z z2m:Zwave ValueAdded: 4-38-1-3 Ignore Start Level
2020-04-12T20:01:00.184Z z2m:Zwave ValueAdded: 4-38-1-4 Start Level
2020-04-12T20:01:00.185Z z2m:Zwave ValueAdded: 4-134-1-0 Library Version
2020-04-12T20:01:00.186Z z2m:Zwave ValueAdded: 4-134-1-1 Protocol Version
2020-04-12T20:01:00.186Z z2m:Zwave ValueAdded: 4-134-1-2 Application Version
2020-04-12T20:01:00.187Z z2m:Zwave ValueAdded: 4-115-1-0 Powerlevel
2020-04-12T20:01:00.187Z z2m:Zwave ValueAdded: 4-115-1-1 Timeout
2020-04-12T20:01:00.188Z z2m:Zwave ValueAdded: 4-115-1-2 Set Powerlevel
2020-04-12T20:01:00.188Z z2m:Zwave ValueAdded: 4-115-1-3 Test Node
2020-04-12T20:01:00.189Z z2m:Zwave ValueAdded: 4-115-1-4 Test Powerlevel
2020-04-12T20:01:00.189Z z2m:Zwave ValueAdded: 4-115-1-5 Frame Count
2020-04-12T20:01:00.190Z z2m:Zwave ValueAdded: 4-115-1-6 Test
2020-04-12T20:01:00.190Z z2m:Zwave ValueAdded: 4-115-1-7 Report
2020-04-12T20:01:00.191Z z2m:Zwave ValueAdded: 4-115-1-8 Test Status
2020-04-12T20:01:00.192Z z2m:Zwave ValueAdded: 4-115-1-9 Acked Frames
2020-04-12T20:01:00.192Z z2m:Zwave ValueAdded: 4-152-1-0 Secured
2020-04-12T20:01:00.193Z z2m:Zwave ValueAdded: 4-91-1-256 Scene Count
2020-04-12T20:01:00.193Z z2m:Zwave ValueAdded: 4-91-1-257 Scene Reset Timeout
2020-04-12T20:01:00.195Z z2m:Zwave ValueAdded: 4-117-1-0 Protection
2020-04-12T20:01:00.196Z z2m:Zwave controller command { nodeid: 4, state: 7, errcode: 0, help: ‘AddDevice Completed’ }
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 94 (COMMAND_CLASS_ZWAVEPLUS_INFO)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 38 (COMMAND_CLASS_SWITCH_MULTILEVEL)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 112 (COMMAND_CLASS_CONFIGURATION)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 133 (COMMAND_CLASS_ASSOCIATION)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 134 (COMMAND_CLASS_VERSION)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 90 (COMMAND_CLASS_DEVICE_RESET_LOCALLY)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 115 (COMMAND_CLASS_POWERLEVEL)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 50 (COMMAND_CLASS_METER)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 152 (COMMAND_CLASS_SECURITY)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 91 (COMMAND_CLASS_CENTRAL_SCENE)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 117 (COMMAND_CLASS_PROTECTION)
OpenZWave Warning, Localization::SetupCommandClass: Localization Warning: No Entry for CommandClass - CC: 34 (COMMAND_CLASS_APPLICATION_STATUS)
2020-04-12T20:01:00.209Z z2m:Zwave Notification from node 4: Notification - NoOperation (2)
2020-04-12T20:01:00.210Z z2m:Zwave ValueAdded: 4-114-1-0 Loaded Config Revision
2020-04-12T20:01:00.210Z z2m:Zwave ValueAdded: 4-114-1-1 Config File Revision
2020-04-12T20:01:00.211Z z2m:Zwave ValueAdded: 4-114-1-2 Latest Available Config File Revision
2020-04-12T20:01:00.211Z z2m:Zwave ValueAdded: 4-114-1-3 Device ID
2020-04-12T20:01:00.212Z z2m:Zwave ValueAdded: 4-114-1-4 Serial Number
2020-04-12T20:01:00.260Z z2m:Zwave ValueAdded: 4-112-1-1 Dimming Speed
2020-04-12T20:01:00.261Z z2m:Zwave ValueAdded: 4-112-1-2 Dimming Speed (From Switch)
2020-04-12T20:01:00.261Z z2m:Zwave ValueAdded: 4-112-1-3 Ramp Rate
2020-04-12T20:01:00.262Z z2m:Zwave ValueAdded: 4-112-1-4 Ramp Rate (From Switch)
2020-04-12T20:01:00.262Z z2m:Zwave ValueAdded: 4-112-1-5 Minimum Level
2020-04-12T20:01:00.263Z z2m:Zwave ValueAdded: 4-112-1-6 Maximum Level
2020-04-12T20:01:00.263Z z2m:Zwave ValueAdded: 4-112-1-7 Invert Switch
2020-04-12T20:01:00.263Z z2m:Zwave ValueAdded: 4-112-1-8 Auto Off Timer
2020-04-12T20:01:00.264Z z2m:Zwave ValueAdded: 4-112-1-9 Default Level (Local)
2020-04-12T20:01:00.265Z z2m:Zwave ValueAdded: 4-112-1-10 Default Level (Z-Wave)
2020-04-12T20:01:00.265Z z2m:Zwave ValueAdded: 4-112-1-11 State After Power Restored
2020-04-12T20:01:00.266Z z2m:Zwave ValueAdded: 4-112-1-12 Association Behavior
2020-04-12T20:01:00.266Z z2m:Zwave ValueAdded: 4-112-1-13 LED Indicator Color
2020-04-12T20:01:00.267Z z2m:Zwave ValueAdded: 4-112-1-14 LED Strip Intensity
2020-04-12T20:01:00.267Z z2m:Zwave ValueAdded: 4-112-1-15 LED Strip Intensity (When OFF)
2020-04-12T20:01:00.268Z z2m:Zwave ValueAdded: 4-112-1-16 LED Strip Effect
2020-04-12T20:01:00.268Z z2m:Zwave ValueAdded: 4-112-1-17 LED Strip Timeout
2020-04-12T20:01:00.269Z z2m:Zwave ValueAdded: 4-112-1-18 Active Power Reports
2020-04-12T20:01:00.269Z z2m:Zwave ValueAdded: 4-112-1-19 Periodic Power & Energy Reports
2020-04-12T20:01:00.269Z z2m:Zwave ValueAdded: 4-112-1-20 Energy Reports
2020-04-12T20:01:00.270Z z2m:Zwave ValueAdded: 4-112-1-21 AC Power Type
2020-04-12T20:01:00.270Z z2m:Zwave ValueAdded: 4-112-1-22 Switch Type
2020-04-12T20:01:00.271Z z2m:Zwave ValueAdded: 4-91-1-0 Scene Count
2020-04-12T20:01:00.271Z z2m:Zwave ValueAdded: 4-91-1-2 Top Button Scene
2020-04-12T20:01:00.271Z z2m:Zwave ValueAdded: 4-91-1-1 Bottom Button Scene
2020-04-12T20:01:00.272Z z2m:Zwave ValueAdded: 4-91-1-3 Config Button Scene
OpenZWave Warning, Node004, Zwave+ Node Type (0x00) - NOT FOUND. No Mandatory Command Classes Loaded:
OpenZWave Warning, Node004, Zwave+ Device Type (0x0600) - NOT FOUND. No Mandatory Command Classes Loaded:
OpenZWave Warning, Node004, ZWave+ Role Type (0x05) - NOT FOUND. No Mandatory Command Classes Loaded:
2020-04-12T20:01:10.306Z z2m:Zwave Notification from node 4: Notification - TimeOut (1)
OpenZWave Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: “SecurityCmd_SupportedGet (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x98, 0x02, 0x25, 0x37, 0x6b”
2020-04-12T20:01:10.497Z z2m:Zwave node 4 AVAILABLE: Inovelli - LZW31-SN Dimmer Red Series (Unknown)
2020-04-12T20:01:10.543Z z2m:Zwave ValueAdded: 4-50-1-0 Electric - kWh
2020-04-12T20:01:10.546Z z2m:Zwave ValueAdded: 4-50-1-2 Electric - W
2020-04-12T20:01:10.548Z z2m:Zwave ValueAdded: 4-50-1-256 Exporting
2020-04-12T20:01:10.548Z z2m:Zwave ValueAdded: 4-50-1-257 Reset
OpenZWave Warning, Node004, CommandClass COMMAND_CLASS_CENTRAL_SCENE HandlerMsg Returned False
OpenZWave Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2020-04-12T20:01:11.344Z z2m:Zwave node 4 ready: Inovelli - LZW31-SN Dimmer Red Series (Unknown)
2020-04-12T20:02:46.949Z z2m:Zwave zwave node 4: changed: 50-1-0:Electric - kWh:0.049 → 0.055
2020-04-12T20:02:46.953Z z2m:Zwave zwave node 4: changed: 50-1-256:Exporting:false → false
2020-04-12T20:04:02.950Z z2m:Zwave zwave node 4: changed: 50-1-2:Electric - W:209 → 0
2020-04-12T20:04:02.954Z z2m:Zwave zwave node 4: changed: 50-1-256:Exporting:false → false
2020-04-12T20:05:26.048Z z2m:Zwave zwave node 4: changed: 50-1-2:Electric - W:0 → 211.8
2020-04-12T20:05:26.051Z z2m:Zwave zwave node 4: changed: 50-1-256:Exporting:false → false
2020-04-12T20:07:20.805Z z2m:Zwave zwave node 4: changed: 50-1-0:Electric - kWh:0.055 → 0.066
2020-04-12T20:07:20.808Z z2m:Zwave zwave node 4: changed: 50-1-256:Exporting:false → false
in a previous attempt to fix this issue i did see “duplicate scene notification …dropping” in the OZW_Log.txt but i am not seeing that since my reset of everything.
has anyone found a solution? i’m moving into a new house and was about to go crazy on inovelli switches but may go back to lutron if i can’t get them working.
