3 Way Setup with ST Dimming
Possibly. I have not tried the 4way myself. Try it and let us know :grin:
It looks like it works when i associate both secondary’s they will now mimic the led status of the dim feature. plus on/off.
So going to throw another wrench in the mix. Can i associate a non load switch to two different load switches. But not associate the two load switches? So i can can control both areas from 1 location but independently control them from there respective load switches?
Ok So it works!!! Controlling two Loads with a non load switch. Works great for my use case. Living Room and Kitchen both have down lights. And i have dimmers on both of them. Then using a Central location that controls both of them as the Great Room. The only thing i dont get is if i turn them off by the Secondary Switch they led status is independent on each load switch. But i am ok with that. I might be able to do a mirror switch led from the Secondary to the load switches so when controlled by the Secondary it shows the proper dim setting.
