3 Way Two Smart w/ Smart Bulbs (Blue Switches) - Can Only Get One Switch Powered On
Got it. Sorry for the delay, busy week at work. I got an AUX switch and tried that in the neutral and non neutral wiring schematics but neither worked. Either the main switch wasn’t powered on (non neutral) or the AUX switch did nothing (Neutral). I made sure to see the white flash after holding up and pressing config 5 times on the smart switch so it was set right. I also tried manually configuring the smart switch like this:
But it did not make a difference. I’m confused about this config as it sounds like it’s intended for the AUX switch but the AUX switch wouldn’t be paired to Z2M.
I really appreciate the help. I hope to replace the majority of my switches with smart ones and I’d like to use inovelli’s since they are so friendly with HA and I like the LEDs. Right now we don’t use our switches since all the bulbs are smart, it’ll be nice to have them back.
Pictures:
Switch 1 Before:
Switch 1 After:
This switch works fine as a single pole switch. The black tape was to keep track of which wire was the “common” wire from before.
Switch 1 shares a box with a dumb switch wired the same as the “before” picture for switch 2 (below).
Switch 2 Before:
White tape marks the “common” wire.
“Switch 2” After:
There is just a hole with wires hanging out here right now because I can’t figure out what to do…
