BLUF:
I have one 3-way light circuit I cannot figure out, and I blew up a switch trying. Is there even a way to do a dumb-switch 3-way given the wiring constraints, or should I bite the bullet & do 2 smarts + smartbulb mode?
Longer:
I’ve got one circuit that is part of a post-construction addon, and the wiring between the two floors is just an absolute nightmare. One (stairwell) has a circuit feeding a junction box; then 2-wire down to the 1st switch, and 3-wire to the remote (dumb).
I don’t see any way I can wire this to make the actual light socket switched. I wired it as always on, and used HA to trigger the light based on the Red 2-1, but could only get the dumb to toggle the Inovelli into “On” status, not off.
Question: Attached the basic wiring diagram, not including the other 3 lines going into that overloaded junction box. Is there even a path out here? I don’t see any way to logically create a supported state, given the 2-wire limit I have to get to the switches - no way for line, Neutral, & Load to move between the fixture & switch A.
