Man, you’re a genius!! That worked!! (left the red plugged into line)
It’s working with both the LZW30 & the GE 46201! That is amazing, I can’t thank you enough!! There’s no danger or fire risk to wiring it this way, right?
Now i’m off to re-add it to the hub & do the associations.
I’m waiting to hear back from @EricM_Inovelli on that one: [HOW-TO] Using the Z-Wave Association Tool in SmartThings - #40 by EAN2007
@JohnRob Quick side note: does this mean that I now have a neutral on that right side that i can safely draw power from for an outlet for a tablet ? (i read that it’s not safe to wire a neutral from an outlet to a ground)
