Check out my new program at GitHub - SoundOfMind/configuration_engine: Deterministic configuration management for home automation devices. Capture known-good device configurations as profiles and apply them to similar devices. · GitHub . If you have devices with a lot of configuration parameters like Inovelli, it allows you to capture and save a profile from your device with all it’s settable parameters. Then you can apply that profile to clone another device. It has features to help manage your library of profiles and analyze your devices. The more complicated your devices are, the more you will enjoy this.
Currently requires a windows computer and Home Assistant with Mosquitto and Zigbee2MQTT. All are invited to use it and it would be great if it could be tested with Mac or Linux, as it is designed to be portable. It could be expanded to use Matter or ZWave if folks have the capability and time.
