Apple Home Setup Huge Tip
After setting up about 80 switches and other Matter/Thread devices at my home with an Apple TV gateway, here is a huge tip I wish I knew earlier.
Although thread is a mesh network, it appears that the initial pairing of the switch needs to happen directly with the gateway. If you have a big house and the gateway is far from the switch:
  1. Move the Apple TV close to the switch and power the Apple TV up. (ie remove HDMI cable, unplug, move it, and plug to an outlet close to the switch)
  2. Look at the home app (tap at top right) and make sure that everything else is connected and there are no “Not responding” devices. This should take a couple of minutes after you move the Apple TV and reconnect it.
  3. Now do the initial pairing of the switch
After the pairing you can move the Apple TV back to its usual position. Everything will work fine.
I am wondering whether this is an Apple TV limitation and whether it is a software or hardware issue.
This is a great suggestion. I can think of a different way to accomplish the same goal:
Is there a way to provide power to the switch near the ATV, before installing the switch in the gang? It could be more efficient to maintain an electrical source next to the ATV specifically for switch pairing rather than moving the ATV every time you need to pair (or re-pair) a switch.
I have a loose surface-mount PVC outlet box with a lamp cord attached, that I use to test/provision all new switches before installing them.
Ironically, my White Series 2-1 Thread switch has been mounted in this box for testing since the day it arrived as a pre-order, since I have no place in the entire house that doesn’t already have a Red Series switch installed…
