Aux switch causing light to dim on any button press in 3-way
Hello all,
My inovelli aux switches just came in and was trying to set these up in both a 3-way and 4-way install. In both instances, I believe I was able to wire things appropriately with a load/line in separate boxes. The aux switches work appropriately (mostly…), allow dimming, etc. with the 2-1 switch. However, pressing any button on the aux switch causes a brief dimming of the lights (up, down, config). It will then proceed to dim, brighten, turn the light off, etc.
I initially thought it was an issue with wiring a 4-way, so I tried on a 3 way with the same issue. My 4 way is working fine after rewiring to work with 3 smart switches and grouping. I also tested another aux switch and different 2-in-1 switch with the same issue. Tried factory resetting, etc. The 2-in-1 is set to dimmer and 3-way with aux.
Anyone have any thoughts?
I have the same issue in my 3-way configuration with neutral. The switches are working as expected aside from this unexpected dimming issue.
I have an Inovelli Blue Dimmer switch as the main switch. My line and load are in the same box. The switch is configured to use the aux switch.
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
