Almost total re-design of the inovelli 4-in-1 sensor driver. I like the device but have never liked the driver (no offense Eric)
Re-engineer of driver using current coding standards
Reduce un-necessary event log chatter (there was a lot of this)
Add TamperAlert capability
Standardize device info and add serialnumber, firmware version, protocol version, hardware version
Got rid of double / redundant motion events
Driver:
https://github.com/djdizzyd/hubitat/blob/master/Drivers/inovelli-4-in-1-sensor.src/inovelli-4-in-1-sensor.groovy
Original thread:
Inovelli LZW-60 4-in-1 Sensor Driver Total re-design of the inovelli 4-in-1 sensor driver. I like the device but have never liked the driver (no offense Eric) Re-engineer of driver using current coding standards Reduce un-necessary event log...
Reading time: 5 mins π
Likes: 57 β€
Pushed an update:
fixed incorrect type definition on temperature
@bcopeland You might want to check the setting for the humidity reporting interval, parameter 102. Looks like itβs not replacing the default with the parameter that I entered in the device set up. I have 180 in it but it still is showing 7200 after configuration.
