Binding blue 2-1, fan canopy
If anyone can help me, i would greatly appreciate it. I have a blue 2-1 switch, a blue fan canopy they are wired and working. I use home assistant with z2m. It is a non neutral setup and the switch is wired to be powered on all the time. it is 1 switch that controlled my light and fan before i put these blue switches in. i don’t even know where to begin with bindings. This is what i would like to happen if it is possible. I want to be able to control my light from the switch on the wall or the fan with the config button on the switch, and i want to be able to control it in home assistant. I REALLY just want to be able to control it from the wall if my home assistant goes down or something and i need to see in my bedroom. i don’t usually touch my lights because i have a presence sensor that turns the philips hue bulbs on and off and i can adjust the brightness in home assistant. They are in zigbee2mqtt also. i just don’t understand the bindings and groups and all of the things i have seen don’t show the canopy, the switch and the bulbs. Thanks for any info that anyone can give me
-Lisa
Here is a help article:
