Black Gen 2 Dimmer not showing up as a button device
Hi all.
I’m fairly new to Hubitat and Inovelli. I have 7 Red Dimmers installed which I’ve been very happy with. Today I installed a Black Dimmer (LZW31 - Firmware: 1.47). When I go to create a rule in Hubitat using the black switch, it doesn’t show up in the list of available “button devices”. All of my Red Dimmers do, but not the new Black one.
I was hoping to set up a rule where a triple-down press would activate night mode and turn off all the other switches.
Any thoughts?
Thanks in advance!
Also… I am using the Inovelli driver from GitHub.
My only other thought is that this falls under “Scene Control” which the Red Series have, but the Black do not. Can anyone confirm or deny this?
I’m not a Hubitat guy, but it sounds as if you are trying to use the Black Series as scene controller. That function isn’t supported on the Black Series. You need a Red Series for that.
Yup, that’s what they’re reporting on the Hubitat forum as well. Thanks for the quick reply!
