Blue 2-1 Binding issue [Help]
So I had bind 2 Phillips Hue bulb to my switch and has been working just fine.
Suddenly the switch could no longer turn on and off the bulbs not matter what I do it wont work, I rebind and unbind and reconfigure and syill no go, I did notice that the switch (unlike my other 20) is missing some bindings…
Please see below:
Switches that is bind and working:
Not working:
BumP
Could you try re-adding the switch of concern back into the zigbee network? See if that restores your missing parameters.
I’m not familiar with the bindings using your setup; for Hubitat, when we enroll the switch back into the network (assuming it wasn’t deleted previously), it’ll recognize the switch and we can push the configs back out as if it didn’t leave the network.
Thanks for your reply!
I re-added the switch before I posted with no success, I even try to bind the missing groups and they dont register. I might try doing a hard reset and see what happens.
Reset and still an issue. Ideas?
