Blue 2-1 HA Zigbee2MQTT bound to groups of Hue - group doesn't respect StateAfterPowerRestored
Several groups for me so far - all new switches. Single and multi switch setups with groups of new Hue bulbs on each. They all act the same. I’ve set StateAfterPowerRestored to 255.
Turning off the switch and the group goes dark as expected. Cycle power (breaker or switch pull) and the switch powers back up and the load meter is off but the group of hue bulbs it is bound too turn on. Each bulb is configured to to return to the last powered state (which was off for this test). The led bar on the switches shows they are “off” but the group of bulbs is on.
Does the switch send to the bound group what its state should be on powerup?
Just connecting a dumb light to a switch works as expected upon power restore so I was wondering about zigbee binding to the hue endpoint group.
NM - it appears the Hue bulbs aren’t taking the settings change right away when changing for remember previous power state. I need to be more patient I guess. Don’t change screens so fast and refresh the setting to verify it took
