Blue 2-1 switching itself off
I have a blue 2-1 switch operating in relay mode. It keeps turning itself off apparently randomly. I have it connected to Home Assistant and checked the logs and there is nothing to turn it off; I saw it turn off myself andchecked immediately. I also have Home Assistant connected to Alexa and checked those logs and there was also nothing since the turn on event about an hour prior.
This is the first time that I’ve caught it happening live; I was right next to the switch, a few feet away. But I’ve come into the room and had it off when it had been on previously and nobody was around many times. Any suggestions?
I know you said you’ve checked the logs, but I’m not sure how/where Alexa Hunches are logged. I’d make sure Alexa Hunches are turned off, at least for the troubleshooting phase. They’re turned on by default.
Ah, thanks for the advice! I checked and there was one hunch that had added this switch to a group; I disabled it, but I don’t think that was the cause because the other lights in that group have not been switching off. Still great to know, much appreciated!
