It is fine to replace an illuminated switch with an Inovelli. You just can’t use an illuminated switch as the dumb switch companion to an Inovelli in a 3-way.
Regarding the 2 circuits in the box, hopefully you just touched the circuit pertaining to the switch leg and left the other as-is. If you are in doubt, get an electrician to take a look to ensure you did it properly.
