Is this type of combo possible? Obviously it would have to all be linked in the hub, so no local control, but i like the red controls i have more than the be blue switches
Yes it’s possible. You would use scenes through your hub. Which hub are you using?
Do the 1st Gen switches support scenes?
Using SmartThings, so setting up a hub based scene wouldn’t be a big deal.
Good question. I misread it as second gen. @Tacotoy what is the model number?
Edit: @harjms even if it doesn’t have scenes the hub could trigger on the toggle and send the corresponding command to the canopy.
lzw36 for the switches, and then haven’t ordered the blue yet.
LZW36 supports multiple scenes. FYI that is considered Gen 2.
