Blue Fan Switch - Voltage Regulation for medium and low?
Is there a way to adjust the voltage that the switch outputs on medium and low? I was able to figure out that the pull chain switch outputs 120v on high, 99v on medium and 84v on low. These voltages work great for the fan speeds.. I have also confirmed the voltages with the wireless transmitter that came with the fan. The blue fan switch does the 120 on high - like 60 ish on medium and like 40 ish ( I could be wrong - but you get the point) on low. The fan still works fine.. just slower. Setting the “dimmer level” of the fan keeps the voltages the same. Would be great if there was a way to set a custom voltage for medium and low on the fan switch.
