This is a weird one and I’m totally lost. I have a blue switch and a hardwired zigbee outlet from Jasco in my master bedroom. I have created a scene when the switch is on it turns the outlet on and one for off. In my zigbee2mqtt dashboard turning on the switch turns on the outlet (connect to 2 lamps). Same when switching it off. However, using the actual inovelli wall switch to turn on or off has no effect. I can hear the relay click on and off, but the outlet is not controlled.
Turning it on and off physically with the switch does not seem to update the mqtt dashboard either.
