Blue Series 2-in-1 refuses to turn on to 100% in ZHA
I’m aware of the oddities with setting this parameter (the visible slider in HomeAssistant seems to do nothing, a value of 254 is 100%, 255 is previous).
Even so, I can’t get this 2-in-1 and aux switch combo to turn my light on to 100% when turned on (locally or remotely). My other individual switches work fine, it’s just this one. Any suggestions?
That option should work for pressing the physical up button. When you say it doesn’t going to 100%, are you seeing that in HA or by looking at the bulb? What are the minimum and maximum values? You should also set DefaultLevelRemote to 254 to cover off->on from HA.
Oh man, that’s it! I was so focused on what it was saying the light was at in HA. HA seems to always show that the light has turned on to the previous % when turning on via the physical switch… but it is indeed going to 100%
Seems like HA catches up much faster for my other switches than this one, but that’s not a big deal I suppose
