Blue series brightness levels
Has anyone noticed that the blue series brightness levels are different from the red series dimmers? On my red series dimmers I can dim to incredibly low levels. On the blue series, same led lights, I can’t dim as low. It’s frustrating because I have a blue series dimmer on my living room lights and I can’t dim to a low enough level, even after changing the minimum load level parameter to 1. Any suggestions?
Thank you for the help.
I can’t compare with the Red series, but yeah, the Blue doesn’t dim as low as my previous dumb dimmer. I dunno if the low end is something that can be changed in firmware, but if it is, I’d like it to dim more.
Same. I have red dimmers in the kitchen and dining room. Not being able to go as low as them is killing me to the point where I want to rip this out.
My Blues dim very low … much better than my Reds.
I think it depends a lot on the lighting fixture you’re using. LED dimming varies a lot between brands and models. But with incandescent bulbs I can dim it down to a just barely visible glow.
I have the following recessed led lights on red and blue series dimmers. There shouldn’t be any difference in my opinion between the brightness levels. I get they are not the same switch but I’m genuinely curious as to if these can go lower with an update.
https://www.homedepot.com/p/Commercial-Electric-Ultra-Slim-4-in-Selectable-CCT-Canless-Color-Integrated-LED-Recessed-Light-Trim-Downlight-650-Lumens-Dimmable-53808101/306179206?cm_mmc=ecc-_-THD_SHIP_CONFIRMATION-_-V1_M1_CC-_-Product_URL&ecc_ord=WB26681350&em_id=f3ea801cb2c6791a0686382acf73a6571cad245dc75b9403e5031bd02e615786
While the brightness at a given dimming level depends on the light, the Blue puts out more power at minimum dimming than my old Lutron:
vs. Blue at brightness 1:
