Blue Series Bulk Configuration (HA and Zigbee2MQTT)
For those that use Home Assistant with Blue Series devices connected via Zigbee2MQTT, I created a blueprint that can help set bulk config settings across multiple devices. I created a topic as well on the Home Assistant community forums where you can find a link to import the blueprint.
This blueprint is designed to simplify configuration of all Inovelli Blue devices (mmWave, Fan, On/Off, Dimmer/2-1 switches and canopy).
All configuration type settings are supported for each device and the automation will adjust to unique settings for device types if grouping them all together. Here are a few key points of the blueprint:
  • Zigbee2MQTT is required
  • Target one or many devices, areas, and/or labels
    • This allows you to target an entire room(s) or send certain configs to specific devices with labels
  • All setting values are set to defaults and disabled in automation, allowing you to only enable and push setting you care about. Automation will filter any devices using labels/areas to only be Inovelli devices using MQTT integration.
  • To push a setting it first needs to be enabled in the blueprint and it will set what ever the value is set to for all targeted devices (if device supports the setting)
  • Settings that are for the state of switch or effects are not supported in this
  • Triggers are optional so it can be run manually as needed or trigger how ever you would like
  • Upon completion a persistent notification will be sent letting you know the bulk configuration settings have been completed
    • Notification has a custom field for setting the title and the body of the message will include all the devices that were targeted
The blueprint seems to no longer be working. Any ideas?
Here is how you can sync settings with ZHA:
