Hello!
I was hoping to reach out to the community about an issue I’ve been having with the Blue Series Fan Switches. I have opened a Support Ticket - but, maybe someone else has found a fix to this they could share.
The first fan switch I installed constantly sent 120V to the fan when off; Smart Mode disabled. I troubleshooted with support and the switch was replaced - all is good. Since then, I’ve installed five more fan switches (and six canopy modules as a couple of switches control multiple fans). All is good. Those that control one fan work fine; those that need to be in Smart Mode, work fine too.
But, the switch I installed today is sending 122V to the load even when off (Smart Mode off). I had another switch handy, so I installed it - same results.
My line and load are not mixed up; I’ve double-checked the fans are set to “load only”, “dimmer/3-speed”, etc. Using Home Assistant, ZHA.
Anyone else experienced a similar issue? Or, have a suggestion for troubleshooting?
Thank You
