Checking that the above is true because z2m says the following:
Default level for the dimmer when it is turned on at the switch. A setting of 255 means that the switch will return to the level that it was on before it was turned off.
I ask because I am having a problem with defaultLevelRemote (Firmware bug: defaultLevelRemote does not work) and wondering if z2m needs updating.
