Blue Series Home Assistant multi clicks not working
Having an issue with recalling presets through double click up/down/ect. I have a single click setup for the config button which works as expected.
First I created a group for the lights and bound the group to the switch. Then I created a scene with the trigger being up/down double clicked and the entity for the group of lights.
When I test these through HA it works as expected. When I use the single config button press on the physical switch, it works as expected. When I use the double click up/down it does not work. If I monitor the last triggered status of automations the config button shows activity as it should but the double clicks are not triggering the automations to be recalled.
Switch Firmware: 0x01020208
Home Assistant 2023.1.4
Supervisor 2022.12.1
Operating System 9.4
Frontend 20230110.0 - latest
Try raising the value of the buttonDelay. You might not be tapping 2x fast enough
You’re awesome, I should have thought about that, I put it down to 0 thinking it would keep things faster on single clicks then added that automations after. Increasing it to 1 did fix the problem. Thank you!
