Blue Series not working with Inovelli Aux
Hi, I have an early Blue series (2208) that isn’t working with the inovelli aux switch. I’ve confirmed the wiring is correct and I’ve swapped out a known working Aux which didn’t fix the issue. I also swapped in a known working 2-in-1 red which did work with the aux switch, so the problem seems to be with the blue switch and not the aux or the wiring.
My firmware is 2.18, the switch is set to on/off, multiway with aux, and smart bulb mode is disabled. Any ideas?
If you’re not on the current firmware, it probably couldn’t hurt to flash it at this point.
2.18 is the latest firmware.
