Just got my inovelli vzm32-sn, I live up in Canada. I bought a 10 pack and started with the easiest switch, two wire, black and white control one light (2 LED Lights in the fixture). I got it hooked up with the black wire up top in the load and the white down in line. Flip my breaker and it leaves me with a flickering light that can’t be controlled and no lights on my switch despite trying reset procedures. Since I have a 10 pack, I tried a second one to the same result. Put back on my old switch and works as expected. Looking for advice on how to get the switch working and stopping the flicker!
So it sounds as if this is a non-neutral? It sounds like you have a single 2-wire in the switch box?
Did you test to determine which of the two conductors was the line?
What is the load? More than likely, once you have the line and load properly identified, you’ll need a bypass at the light to ensure the switch gets enough power to function.
This topic was automatically closed after 75 days. New replies are no longer allowed.
