VZM31SN + VZM36
Home Assistant Zigbee
Can someone help me track down where something is programed wrong?
Recently I had to reprogram the Fan & Switch after something caused it to reset during a snow storm with power loss. Going to guess recloser timing on the power outage.
Before hand I had followed the instructions and had it working perfectly with binding and the config button to control the fan speeds (Low,Med,High,Off).
I reconnected them and thought I had everything working as it was before however it’s not.
Currently when I press the config button on the switch it shows that the fan is on low however the fan speed is on high for all of the levels. So it’s showing it as intended on the switch but the fan is pretty much full blast or off.
Where am I going wrong here? I made sure the cluster on the switch was set to 2 and it shows it currently is when I read the attribute.
Is there an easy way to pull all of the settings and let someone look at it on here to help me figure out what’s going on before my wife kills me over the smart house.
Thanks for any help
