**I am seeing a trend of half of the below switches dropping off the mesh, the switch in HA grey and I have to repair half the time to switch back to HA. Not sure why this is happening, I have a very stable zigbee mesh in the house.
I have also been having this issue for about the last 6 weeks. We went on vacation, and almost half the switches went unavailable during that time. When I got back I had to pull the air gap to reboot them. Since then barely a week goes by before I have a half a dozen in that state. I’m getting close to the point that I’m just going to pull the air gap on about a quarter of them every weekend to see if that helps. About the only difference between my setup and yours is that I’m using the Zigbee radio built into the HA Yellow.
Actually, it started happening now for all my blue series Inovelli switches. all other zigbee devices (100+) work without any issues at all. Also, all switches are updated using the latest version
I have a second antenna that is Z2M , starting to move them over to z2m and see if the issue is resolved , so far I have not noticed a switch fall off of z2m
Annoying that these switches fall off of zha, glad to hear I am not alone …lol
Home Assistant Connect ZBT-2 is the antenna I have on z2m
This is actually being discussed over on the VZM31-SN firmware changelog thread. Anecdotally there seem to be a bunch of ZHA related sightings of this but none on Z2M. I’m on Z2M now and my 9 have been good
The problem is a code change in ZHA quirks so Z2M is unaffected. I will once again suggest migrating to Z2M if able. It’s much more stable, exposes more functionality and is much faster for the community and Inovelli to get changes made to the converters.
Is there any kind of seamless migration tool from ZHA to Z2M? I just can’t manually recreate every Zigbee device and then rewrite all the automations and dashboards I have. It’s easier to just reboot the switches periodically.
You could get a second antenna dedicated to Z2m and just put your Inovelli on it , that is what I have done so far
This is what I have been doing to make it easier , move one device at a time then to protect your automations. In Z2M, name the device and check the box to also rename in Home Assistant — that keeps entity IDs stable so automations and dashboards don’t break. Matching the friendly name alone doesn’t guarantee HA reuses the old entity ID, so check the rename box.
Same issue here on ZHA (HA 2026.11, SLZB-06M coordinator, channel 25). VZM32 is on 0x01030102 and VZM30 on 0x01100103.
When a switch drops, the paddle still controls the load, but it’s completely silent on Zigbee. The air gap brings it right back without re-pairing.
Every recent dropout on my network has been a VZM32 or VZM30. None of my VZM31s or VZM35s have dropped. In ZHA’s code, the VZM32 and VZM30 are the models that get their power readings (0x0B04) polled every 30-45 seconds. VZM31 is exempt because it reports on its own, and VZM35 isn’t polled. That could explain why Z2M users don’t see this.
I’ve turned off the power sensors on three switches that drop often to stop the polling, and I’ll report back.
@Inovelli: is a Zigbee-only hang a known issue on these firmware versions, and does VZM32 1.03 address it?
