Hi there,
I am trying to configure my switches to use trailing edge. I have successfully done this on one other switch, but with most of my switches I am unable to make this change. All of my switches are neutral connected.
- Switch that worked is in Single Pole, Dimmer mode, version 2.18
- Switches that didn’t work are:
- in Multi Pole, Dimmer mode, with Aux switches, on version 2.18
- in Single Pole, Dimmer mode, version 2.18
I am doing this at the switch using the Paddle Down + Config 13x combo. I do not see any sort of confirmation light at the end, and I can confirm from ZHA that parameter 26 is still bool.False.
What am I missing?
I also am aware that you cannot configure this from the HA UI. I do think we should make this more clear in HA that it’s not remotely configurable; I’ve spent hours trying to make that work until I stumbled across this thread – Can’t set parameter 26 (Leading or Failing Edge) to True on Inovelli Blue 2-1 switches
