Blue Switch + Fan Canopy Module Interaction
I have a VZM-36 connected to a VZM31-SN. Both are paired to HA with ZHA. I can control them well independently, but I’m having trouble configuring the switch to control the distinct canopy module functions.
I’ve put the switch to smart bulb mode and bound it to the canopy. Right now if I turn the switch on, both the fan and light turn on.
I’d like the main paddle to control the fan light on/off/dim. I’d like the config/favorites button to cycle through fan speeds. If I can do this with local binding that would be great too but it’s not required. Bonus points if the LED can display the current fan speed level if the secondary button has been pressed recently.
I think this is a pretty straight forward ask but I’m not even seeing how to change what the config button does in the list of parameters. If its not possible, I’m open to ideas on a simple way to control light and fan separately from the single switch.
Firmware on both devices is listed as Unknown.
Thanks for your help.
