Bulb does not turn on at low dim
On the blue series (and red I believe), there’s a parameter called Quick Start Time (and Quick Start Level) for those specific situations. It basically had the switch provide a jolt of power at a higher amount before dropping back to the dimmed amount when turning on. This resolves issues like you are describing.
I do not know if it’s supported on the white series since I don’t have one.
