Bulb Flare with Inovelli White Dimmer
Hi all. Installed a White series dimmer connected to two fixtures with 4 led bulbs total. I don’t want to dim: just on/off. In toggle switch mode the bulbs get extra bright for 1/2 a second then dim down slightly to a consistent brightness. I changed the switch to dimmer mode and even setting maximum brightness still causes the initial bright flash. What should I check? I assume this isn’t expected behavior. Note: I’m considering using non-dimmable bulbs to see if that makes a difference but haven’t tried that yet.
Forgot to mention I’ve tried two different brands of led bulbs; however, both were fairly cheap.
