9 X Sigalux E12 3W (40W equivalent) LED
Try changing from leading to trailing edge, or vice versa, depending on how you’re presently set. If that doesn’t get it, you’ll probably have to try a different brand of bulbs.
Switching it to trailing edge reduced the flashing somewhat, but it is still very noticeably strobing — like, could cause seizures in someone sensitive to flashing lights. Bulbs still all turn off ok. Strange that this switch and bulbs were working perfectly fine until about a week ago. Ok… So now I guess I have to look into buying new lightbulbs. Is there a master list that is updated with LED bulbs that will work seamlessly with this the white series smart dimmer (formerly known as the 2-1 switch)?
I need 9 X E12 bulbs. I would like LED’s that are no more than 40W equivalent
There is a bulb compatibility guide, but I don’t think it is very up-to-date.
Do you have another switch to swap in? I I think you should verify that the issue is not the switch before going down another path.
I don’t have another switch. This was my first (and currently only) smart dimmer switch. The previous switch was an old Lutron toggle dimmer switch, but I’m trying to integrate the lights into the lights into the Apple Home app. They were working fine up until a week ago. I could turn them on and dim them through the wall switch, Apple Home app, and via Siri voice control. I don’t know if I accidentally did something or what would cause them to suddenly have all these problems
