Can you turn on the load without LED bar turning on?
Yes, with local protection on, you can press up on the paddle without the LEDs illuminating for “on”. However, as soon as the automation turns on the load, the LEDs illuminate for “on” and block the notification I’m trying to display.
So the issue is you can’t do these at the same time:
  • Switch on the load
  • Show a notification
Without the “on” state of the LEDs blocking the notification for a few seconds.
Unless (hopefully) there’s another idea out there (or a firmware update).
